* Makefile.am: Merge-in bootloader/Makefile.am, clock/Makefile.am,
console/Makefile.am, include/Makefile.am, irq/Makefile.am,
motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am,
residual/Makefile.am, start/Makefile.am, startup/Makefile.am,
vectors/Makefile.am, vme/Makefile.am. Use automake compilation rules.
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, motorola/Makefile.am,
openpic/Makefile.am, pci/Makefile.am, residual/Makefile.am,
start/Makefile.am, startup/Makefile.am, vectors/Makefile.am,
vme/Makefile.am: Remove.
* bootloader/Makefile.am: Put all files into EXTRA_DIST.
* vme/Makefile.am: Ditto.
* console/Makefile.am: Move H_FILES to include_bsp_HEADERS.
Add preinstallation dirstamp support.
* irq/Makefile.am: Ditto.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* Makefile.am: Remove empty lines.
* clock/Makefile.am: Ditto.
* include/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
bootloader/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
motorola/Makefile.am: Reflect having moved automake.
openpic/Makefile.am: Reflect having moved automake.
pci/Makefile.am: Reflect having moved automake.
residual/Makefile.am: Reflect having moved automake.
vme/Makefile.am: Reflect having moved automake.
converted to automake.
