PR 833/bsps
* irq/irq_asm.S: Currently, all (new exception) BSPs explicitely enable
the FPU across the user ISR but DONT save/restore the FPU context.
Any use of the FPU fron the user handler (e.g., due to GCC
optimizations) result in corruption. The fix results in an exception
in such cases (user ISR must explicitely save/enable/restore FPU).
* startup/bspstart.c: Rewrote get_eumbbar() in C. Function was written
in inline assembly and containined a register direction error.
* clock/p_clock.c, irq/i8259.c, irq/irq.c, irq/irq.h: Modified to use
rtems/irq.h.
* bootloader/bootldr.h, bootloader/em86.c, bootloader/misc.c,
bootloader/pci.c, bootloader/pci.h: Modified to depend upon
rtems/pci.h
* startup/bspstart.c, tod/todcfg.c:
Eliminate {un|}signed{8|16|32}.
* bootloader/pci.c: Eliminate {un|}signed{8|16|32}.
Eliminate u32.
* pci/pci.h: Add pci_bus_count().
* irq/irq_init.c, pci/pci.c, pci/pcifinddevice.c, startup/bspstart.c:
Name change to support common PCI interface
* console/uart.h: Eliminate tabs.
PR 779/bsp
* clock/p_clock.c, console/console.c, console/uart.c, console/uart.h,
irq/irq.c, irq/irq.h, irq/irq_init.c:
powerpc: add parameter to new exception interrupt handlers
* pci/pci.c, pci/pci.h, pci/pcifinddevice.c: Continue PCI API
unification. All use pci_find_device(). Also reformat to remove tabs.
* pci/pci.c, pci/pcifinddevice.c, startup/bspstart.c: Make PCI
initialize function part of the unified PCI API as pci_initialize().
* startup/bspstart.c: Eliminate rtems_unsigned32.
* startup/bspstart.c: include <rtems/powerpc/powerpc.h>.
Use PPC_MINIMUM_STACK_FRAME_SIZE instead of
CPU_MINIMUM_STACK_FRAME_SIZE.
* start/start.S: include <rtems/powerpc/powerpc.h>.
* pci/pci.h: Remove contents that are duplicates of the pci.h in cpukit
and include rtems/pci.h for the base set of PCI functionality.
* tod/todcfg.c: size_t RTC_Count.
* ChangeLog, startup/bspstart.c, tod/todcfg.c: Remove warnings.
Greg Menke 12/06/2004
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
a significant amount of spelling and whitespace cleanup.
* tod/todcfg.c: New file.
PR 606/bsps
* bootloader/pci.c: Fixed IO remapping so buses >= 1 are remapped.
Reduced PCI space to match bat2. Fixed incorrect region size
calculation in pci_read_bases. Set PCI latency timers to known
sane values. Changed bridge PCI settings to minimum sane instead
of whatever sounded neat in the PCI spec. Force pf regions to
memory mapped to preserve byte access.
PR 608/bsps
* pci/pcibios.c: Added BusCountPCI()
* include/bsp.h: Remove (Unused).
* Makefile.am: Reflect change above.
* bootloader/exception.S: Include <rtems/asm.h> instead of <asm.h>.
* bootloader/head.S: Include <rtems/asm.h> instead of <asm.h>.
* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* start/rtems_crti.S: Include <rtems/asm.h> instead of <asm.h>.
* start/start.S: Include <rtems/asm.h> instead of <asm.h>.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* bootloader/misc.c, bootloader/pci.c, console/inch.c,
include/bsp.h, pci/pci.c, startup/bspstart.c, startup/sbrk.c:
Convert to using c99 fixed size types.
* bootloader/pci.c: Remove warnings by adding include <string.h>.
* irq/irq.c: Clean up includes to remove warnings.
* pci/pci.c, pci/pci.h, startup/bspstart.c: Better use of const
on struct _int_map.
* vectors/vectors.h, vectors/vectors_init.c: Undo previous change.
* Makefile.am: Remove startup/linkcmds.
PR 575/bsps
* startup/linkcmds: Remove.
* vectors/vectors.h: Force globalExceptHdl into bss section.
* Makefile.am: Don't install, just distribute the files.
* Makefile.am: Remove SUBDIRS.
* Makefile.am: Merge-in bootloader/Makefile.am, clock/Makefile.am,
console/Makefile.am, include/Makefile.am, irq/Makefile.am,
motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am,
residual/Makefile.am, start/Makefile.am, startup/Makefile.am,
vectors/Makefile.am, vme/Makefile.am. Use automake compilation rules.
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, motorola/Makefile.am,
openpic/Makefile.am, pci/Makefile.am, residual/Makefile.am,
start/Makefile.am, startup/Makefile.am, vectors/Makefile.am,
vme/Makefile.am: Remove.
* console/Makefile.am: Add PREINSTALL_DIRS.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* motorola/Makefile.am: Add PREINSTALL_DIRS.
* openpic/Makefile.am: Add PREINSTALL_DIRS.
* pci/Makefile.am: Add PREINSTALL_DIRS.
* residual/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* console/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Ditto.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* console/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* motorola/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* openpic/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pci/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* residual/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* start/Makefile.am: Remove empty lines.
* bootloader/Makefile.am: Put all files into EXTRA_DIST.
* vme/Makefile.am: Ditto.
* console/Makefile.am: Move H_FILES to include_bsp_HEADERS.
Add preinstallation dirstamp support.
* Makefile.am: Remove empty lines.
* clock/Makefile.am: Ditto.
* include/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
PR 510/bsps
* irq/irq.h: Add extern C wrapper.
PR 497/bsps
* bootloader/head.S: Disable code that returned to the firmware when
the loader starts.
PR 496/bsps
* startup/sbrk.c: New file.
* startup/bspstart.c: This patch implements 'sbrk'
for the powerpc-shared BSP to work around what's known as the
'32Mb problem' in combination with run-time loaded code.
GCC normally generates (PowerPC) code doing 'short jumps' which
requires all text segments being in the same 32Mb area of memory.
However, some run-time loaders use (e.g. heap-) memory violating the
stated limitation on hardware with more than 32Mb of memory.
(NOTE: portable loaders are probably not even aware of this
GCC/CPU specific problem.)
This patch implements a simple workaround: At boot time, the system is
only provided with 32Mb of memory. The user is supposed to load all
necessary modules prior to that limit being exhausted. Once that
happens, newlib/malloc end up trying to 'sbrk()' for more memory and
the implementation provided by this patch will then make the rest of
the physical memory available.
PR 497/bsps
* bootloader/head.S: Let the bootloader shut down the
network interface. NOTE: this involves a PPCBug system
call and will hence fail if other software is used
to boot. Need to #undef USE_PPCBUG in such cases!
* bootloader/bootldr.h, bootloader/em86.c, bootloader/em86real.S,
bootloader/exception.S, bootloader/head.S, bootloader/lib.c,
bootloader/misc.c, bootloader/mm.c, bootloader/pci.c,
clock/p_clock.c, console/console.c, console/consoleIo.h,
console/inch.c, console/keyboard.h, console/polled_io.c,
include/bsp.h, irq/i8259.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, motorola/motorola.c, motorola/motorola.h,
openpic/openpic.c, openpic/openpic.h, pci/pci.c, residual/residual.c,
start/start.S, startup/bspstart.c, vectors/vectors.h,
vectors/vectors_init.c: URL for license changed.
PR 456/bsps
* irq/irq.c: Fix race condition when installing an ISR.
bootloader/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
motorola/Makefile.am: Reflect having moved automake.
openpic/Makefile.am: Reflect having moved automake.
pci/Makefile.am: Reflect having moved automake.
residual/Makefile.am: Reflect having moved automake.
vme/Makefile.am: Reflect having moved automake.
PR 437/bsps
* irq/irc.c: calls to bspIo/printk must not use '%i' format which is
apparently not supported
* pci/pci.c: calls to bspIo/printk must not use '%i' format which is
PR 288/rtems
* irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly
maintained and any BSP which does not do so will trip a panic in the
shared code.
