Updates #2458.
* console/console.c, startup/genpvec.c, startup/setvec.c: Disable call
to rtems_interrupt_catch until it is fixed. Need to disabled
set_vector.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, console/85c30.h,
console/console.c, console/consolebsp.h, console/tbl85c30.c,
include/gen2.h, irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c,
pci/no_host_bridge.c, startup/bspclean.c, startup/bspstart.c,
startup/genpvec.c, startup/vmeintr.c: File head clean up.
* Makefile.am, PCI_bus/PCI.c, PCI_bus/universe.c, startup/genpvec.c:
Fix warnings.
* Makefile.am, preinstall.am, PCI_bus/PCI.c, PCI_bus/PCI.h,
PCI_bus/universe.c, console/85c30.c, console/85c30.h,
console/consolebsp.h, console/tbl85c30.c, include/gen2.h,
startup/Hwr_init.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Some clean up.
* include/coverhd.h: Removed.
* Makefile.am, README, configure.ac, console/85c30.c,
console/console.c, console/consolebsp.h, include/bsp.h,
start/start.S, startup/bspstart.c, startup/genpvec.c,
startup/linkcmds, timer/timer.c, tod/tod.c: Initiate update and
testing. Runs hello but does not run ticker yet.
* c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c: Change to
the Chains API.
* PCI_bus/universe.c, console/console.c, include/bsp.h, irq/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/spurious.c: Eliminate
DEBUG_puts.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* startup/genpvec.c: Include <rtems/chain.h> instead of <chain.h>.
* console/consolebsp.h: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* startup/vmeintr.c: Include <rtems/vmeintr.h> instead of <vmeintr.h>.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c,
clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, include/bsp.h, include/gen2.h, startup/FPGA.c,
startup/spurious.c, startup/vmeintr.c, timer/timer.c, tod/tod.c:
Convert to using c99 fixed size types.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/85c30.h,
console/consolereserveresources.c, console/tbl85c30.c, include/bsp.h,
include/coverhd.h, include/gen2.h, include/tod.h, startup/FPGA.c,
startup/bspclean.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c: URL
for license changed.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, console/consolereserveresources.c,
console/tbl85c30.c, include/bsp.h, include/coverhd.h, include/gen1.h,
include/gen2.h, startup/82378zb.c, startup/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/setvec.c,
startup/vmeintr.c, timer/timer.c: Fixed typo.
* startup/genpvec.c: #include <chain.h> instead of "chain.h", fix
CVS-Id.
* include/chain.h: Remove.
* include/Makefile.am: Remove chain.h.
