Reflect changes to bsp.am.
PCI_bus/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
This was tracked as PR87.
* README, configure.ac, include/Makefile.am, include/bsp.h,
start/start.S, startup/FPGA.c, startup/Makefile.am, tod/Makefile.am:
Eliminated conditional code for generation 1 boards as these are
no longer available.
* include/gen1.h, startup/82378zb.c, tod/tod_g1.c: Deleted.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/score603e.cfg;
Add automake conditional for SCORE_GENERATION_1;
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* start/start.S: include <bspopts.h> instead of targopts.h.
* tod/Makefile.am: Apply SCORE_GENERATION_1 conditional.
* vectors/vector.S: include <bsp.h>.
* wrapup/Makefile.am: Apply @exceptions@.
* startup/genpvec.c: #include <chain.h> instead of "chain.h", fix
CVS-Id.
* include/chain.h: Remove.
* include/Makefile.am: Remove chain.h.
converted to automake.
