path: root/c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (follow)
* 2004-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-311-31/+0
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, PCI_bus/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, vectors/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, PCI_bus/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, vectors/Makefile.am: Remove. * configure.ac: Reflect changes above. * wrapup/Makefile.am: Reflect changes above.
* 2003-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-221-1/+1
| | | | | | | | | | | * PCI_bus/Makefile.am: Eliminate VPATH. * clock/Makefile.am: Eliminate VPATH. * console/Makefile.am: Eliminate VPATH. * start/Makefile.am: Eliminate VPATH. * startup/Makefile.am: Eliminate VPATH. * timer/Makefile.am: Eliminate VPATH. * tod/Makefile.am: Eliminate VPATH. * vectors/Makefile.am: Eliminate VPATH.
* 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-031-1/+0
| | | | | | | | | | | | * Makefile.am: Add preinstallation dirstamp support. * PCI_bus/Makefile.am: Cosmetics. * clock/Makefile.am: Cosmetics. * console/Makefile.am: Cosmetics. * startup/Makefile.am: Cosmetics. * timer/Makefile.am: Cosmetics. * tod/Makefile.am: Cosmetics. * vectors/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-021-1/+1
| | | | | | | | | | | | * PCI_bus/Makefile.am: Remove all-local: $(ARCH). * clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * timer/Makefile.am: Remove all-local: $(ARCH). * tod/Makefile.am: Remove all-local: $(ARCH). * vectors/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. PCI_bus/Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. tod/Makefile.am: Reflect having moved automake. vectors/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* 2002-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-171-1/+0
| | | | | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * PCI_bus/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg. * tod/Makefile.am: Don't include @RTEMS_BSP@.cfg. * vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | * PCI_bus/Makefile.am: Use .$(OBJEXT) instead of .o. * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * tod/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | * PCI_bus/Makefile.am, clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-311-0/+33
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
