* | bsps: Move startup files to bsps | Sebastian Huber | 2018-04-20 | 1 | -368/+0 |
| | | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsp/qoriq: Fix hypervisor guest MMU config | Sebastian Huber | 2018-01-22 | 1 | -27/+71 |
| | | | | | | | | Account for DPAA resources defined in the device tree. Prevent merging of areas with incompatible MAS2. Update #3085. | ||||
* | bsp/qoriq: 64-bit MMU support | Sebastian Huber | 2017-08-22 | 1 | -27/+27 |
| | | | | Update #3082. | ||||
* | bsp/qoriq: Fix tlbwe synchronization | Sebastian Huber | 2016-07-28 | 1 | -1/+1 |
* | bsp/qoriq: Add T2080RDB and T4240RDB variants | Sebastian Huber | 2015-01-13 | 1 | -6/+20 |
* | bsp/qoriq: Add MAS7 support for MMU | Sebastian Huber | 2015-01-09 | 1 | -3/+13 |
| | | | | | This enables usage of the full real address space which is 40-bit on the T2080 for example. | ||||
* | 2011-07-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-07-21 | 1 | -0/+302 |
PR 1799/bsps * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, clock/clock-config.c, console/console-config.c, console/uart-bridge-master.c, console/uart-bridge-slave.c, include/.cvsignore, include/bsp.h, include/hwreg_vals.h, include/intercom.h, include/irq.h, include/mmu.h, include/qoriq.h, include/tm27.h, include/tsec-config.h, include/u-boot-config.h, include/uart-bridge.h, irq/irq.c, make/custom/qoriq.inc, make/custom/qoriq_core_0.cfg, make/custom/qoriq_core_1.cfg, make/custom/qoriq_p1020rdb.cfg, network/if_intercom.c, network/network.c, rtc/rtc-config.c, shmsupp/intercom-mpci.c, shmsupp/intercom.c, shmsupp/lock.S, start/start.S, startup/bsppredriverhook.c, startup/bspreset.c, startup/bspstart.c, startup/linkcmds.base, startup/linkcmds.qoriq_core_0, startup/linkcmds.qoriq_core_1, startup/linkcmds.qoriq_p1020rdb, startup/mmu-config.c, startup/mmu-tlb1.S, startup/mmu.c: New files. |
