* | bsp/qoriq: New BSP names | Sebastian Huber | 2017-07-28 | 1 | -36/+0 |
| | | | | | | | | Due to the FDT support we can now reduce the BSP variants. Use the processor core to define the BSP variants. Update #3082. Update #3085. | ||||
* | bsp/qoriq: Do not touch MMU config for SMP start | Sebastian Huber | 2016-03-03 | 1 | -1/+1 |
| | | | | Assume that the boot page is visible in the currently unused heap area. | ||||
* | bsps/powerpc: Add .nvram section | Sebastian Huber | 2012-12-03 | 1 | -2/+4 |
* | bsps: Replace NIRVANA region | Sebastian Huber | 2012-06-12 | 1 | -3/+2 |
| | | | | | Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS" region. Move the region definition into the "linkcmds.base" files. | ||||
* | bsps/powerpc: Add load section for .nocache | Sebastian Huber | 2012-06-04 | 1 | -1/+2 |
* | bsps/powerpc: Add no cache section | Sebastian Huber | 2012-04-24 | 1 | -0/+1 |
* | 2011-07-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-07-21 | 1 | -0/+33 |
PR 1799/bsps * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, clock/clock-config.c, console/console-config.c, console/uart-bridge-master.c, console/uart-bridge-slave.c, include/.cvsignore, include/bsp.h, include/hwreg_vals.h, include/intercom.h, include/irq.h, include/mmu.h, include/qoriq.h, include/tm27.h, include/tsec-config.h, include/u-boot-config.h, include/uart-bridge.h, irq/irq.c, make/custom/qoriq.inc, make/custom/qoriq_core_0.cfg, make/custom/qoriq_core_1.cfg, make/custom/qoriq_p1020rdb.cfg, network/if_intercom.c, network/network.c, rtc/rtc-config.c, shmsupp/intercom-mpci.c, shmsupp/intercom.c, shmsupp/lock.S, start/start.S, startup/bsppredriverhook.c, startup/bspreset.c, startup/bspstart.c, startup/linkcmds.base, startup/linkcmds.qoriq_core_0, startup/linkcmds.qoriq_core_1, startup/linkcmds.qoriq_p1020rdb, startup/mmu-config.c, startup/mmu-tlb1.S, startup/mmu.c: New files. |
