* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
PR 581/bsps
* Makefile.am, bsp_specs, configure.ac, include/bsp.h, include/tm27.h,
start/start.S, startup/bspstart.c, startup/linkcmds,
tools/Makefile.am, tools/psim, vectors/vectors.S, wrapup/Makefile.am:
Convert PSIM to new exception model.
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: New files.
* startup/setvec.c, timer/timer.c: Removed.
* wrapup/Makefile.am: Convert to automake-building rules.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
vectors/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, vectors/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* wrapup/Makefile.am: Remove GENERIC_FILES.
* startup/linkcmds: Preparations for gcc-3.3.x.
* shmsupp/Makefile.am: Cosmetics.
* vectors/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
shmsupp/Makefile.am: Reflect having moved automake.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/psim.cfg;
Remove RTEMS_OUTPUT_BUILD_SUBDIRS;
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
vectors/Makefile.am, wrapup/Makefile.am: Include compile.am
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
converted to automake.
