* | bsp/psim: Use plain symbol for PSIM | Sebastian Huber | 2013-06-28 | 1 | -13/+0 |
| | | | | This avoids a linker assertion failure in the GCC test suite. | ||||
* | 2008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-05 | 1 | -0/+15 |
* Makefile.am, preinstall.am, shmsupp/getcfg.c, shmsupp/lock.c, startup/linkcmds: Now running mptests using new memory layout with updates patches against gdb 6.8. * include/psim.h, startup/psim_registers.c: New files. |
