* Makefile.am, irq/irq.h: Merge c_rtems_main() into boot_card(). This
eliminated a file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* Makefile.am: Don't include subdirs.am.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
PR 581/bsps
* Makefile.am, bsp_specs, configure.ac, include/bsp.h, include/tm27.h,
start/start.S, startup/bspstart.c, startup/linkcmds,
tools/Makefile.am, tools/psim, vectors/vectors.S, wrapup/Makefile.am:
Convert PSIM to new exception model.
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: New files.
* startup/setvec.c, timer/timer.c: Removed.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Cosmetics.
* Makefile.am: Add $(TMPINSTALL_FILES) to all-local.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
vectors/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, vectors/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* shmsupp/Makefile.am: Cosmetics.
* vectors/Makefile.am: Cosmetics.
shmsupp/Makefile.am: Reflect having moved automake.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/psim.cfg;
Remove RTEMS_OUTPUT_BUILD_SUBDIRS;
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
converted to automake.
