Close #3250.
Close #4081.
Update #4267.
controller support.
Update #3269.
Close #3375.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
The VME support is only used by powerpc BSPs.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Use only one timer driver variant based on the standard PowerPC time
base.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
This collection of BSPs shared the linker script shared/startup/linkcmds.
I renamed that ot shared/startup/linkcmds.share and made a BSP family
specific startup/linkcmds. This was needed because each BSP family had
a different combination of start file name, undefined symbols, etc.
Updates #3520.
maintain.
Update #3254.
Update #3239.
Update #2408.
Update #2408.
