Update #3285.
Update #2408.
BSPs can use the bsp_fatal_extension() to provide BSP-specific fatal
error handling. There is no need for a _BSP_Fatal_error().
Close #3246.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Update #2408.
Also use the const qualifier on the address pointer's target in in_*()
Closes #2128
warning and clean up
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
PR 1685/bsps
* startup/bspstart.c: Add BSP_poll_char.
* startup/bspstart.c, startup/misc.c:
Fixed compiler warnings by adding prototypes to function
declarations and moving extern declarations to global scope.
* start/start.S, startup/bspstart.c:
let 'save_boot_params()' return a pointer to the commandline
saved by the BSP and pass this pointer on to 'boot_card()'.
* include/bsp.h, start/start.S, startup/bspstart.c:
removed BSP_INIT_STACK_SIZE -- this BSP now also uses
__stack defined by the linker script for the initial
stack.
Removed legacy code (inherited from old mvme2307 BSP
but not relevant to this one) that tested trapping
into PPCBug.
* Makefile.am, configure.ac, include/bsp.h, include/bspopts.h.in,
startup/bspstart.c: Add use of bsp_get_work_area() in its own file
and rely on BSP Framework to perform more initialization.
* startup/bspstart.c: Review of all bsp_cleanup() implementations. In
this phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* startup/bspstart.c: removed warning about SPRG0
now being used for IRQ mask; this BSP is OK.
* include/bsp.h, startup/bspstart.c: confdefs.h now wants
us to use BSP_INTERRUPT_STACK_SIZE instead of
CONFIGURE_INTERRUPT_STACK_MEMORY. Removed reference to
CONFIGURE_INTERRUPT_STACK_MEMORY from bspstart.c
* start/start.S, startup/bspstart.c: disable memory-select
errors early (in start.S) to avoid hangs due to speculative
memory access (motload maps absent memory in TLBs).
Remove TLB mappings for which no physical memory is installed
(bspstart). Enable HID1[RFXE] so that 'core_fault_in' errors
result in a machine-check rather than stalling the machine.
Re-enable memory-select errors at this point.
* startup/bspstart.c: Fixes a lockup which occurs when a speculative
load occurs from a particular range of memory.
