* | bsps: Move I2C drivers to bsps | Sebastian Huber | 2018-04-23 | 1 | -75/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsps/powerpc: Fix mpc83xx_i2cdrv.h location | Sebastian Huber | 2017-12-07 | 1 | -1/+1 |
| | | | | Update #3254. | ||||
* | bsps/powerpc: Add probe handler to I2C driver | Sebastian Huber | 2013-01-09 | 1 | -2/+7 |
* | bsp/mpc55xx: Add and use MPC55XX_CHIP_FAMILY | Sebastian Huber | 2012-10-02 | 1 | -1/+1 |
* | 2011-08-31 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-08-31 | 1 | -5/+5 |
| | | | | | | | | | | | | | | | | | | | | * startup/bspgetworkarea.c, startup/linkcmds.base: Removed files. * include/mpc55xx-config.h, make/custom/mpc5674fevb.cfg, startup/early-init.c, startup/ebi-cal-cs-config.c, startup/ebi-cs-config.c, startup/exc-vector-base.S, startup/fmpll-syncr-vals.c, startup/linkcmds.mpc5674fevb, startup/mmu-config.c, startup/siu-pcr-config.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * startup/linkcmds.gwlcfm, startup/linkcmds.mpc5566evb, startup/linkcmds.phycore_mpc5554: Use linker command base file. * configure.ac: Support MPC5674F. Changed eSCI options. * clock/clock-config.c: Support MPC5674F. * i2c/i2c_init.c, network/smsc9218i.c, startup/sd-card-init.c: Update due to API changes. * include/bsp.h: Define BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN. * network/if_smc.c: Use HAS_SMC91111. * startup/start.S, startup/bspstart.c: Moved low-level initialization into new files. Overall cleanup. | ||||
* | 2010-12-22 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-22 | 1 | -84/+42 |
| | | | | | | | | | | | * configure.ac: Added I2C options. Fixed eMIOS prescaler. Use standard linker command file support. * include/bsp.h: Declare I2C initialization function. * i2c/i2c_init.c: Implementation. * make/custom/gwlcfm.cfg, make/custom/mpc5566evb.cfg, make/custom/mpc55xx.inc: Use standard linker command file support. * startup/bspstart.c: More board specific settings. * Makefile.am, preinstall.am: Reflect changes above. | ||||
* | add support for mpc551x based GW_LCFM system | Thomas Doerfler | 2010-03-25 | 1 | -0/+112 |
