Update #3285.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
Rework of the start sequence to reduce the amount assembler code and to
support configuration tables which may be provided by the application.
