line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* include/tm27.h:
PR 615/bsps
* include/tm27.h: Removing USE_ENHANCE_INTR_API conditional check since
that is the only kind this BSP supports and tm27 does not care which
interrupt model is used as long as the macros are properly defined.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
