PR 822/bsps
* console/console.c, startup/bspstart.c, startup/imbx8xx.c,
startup/mmutlbtab.c, startup/start.S, vectors/vectors_init.c:
Currently the MBX8xx BSP does not boot, because some logical errors
are in the startup code. Additionally, the mpc8xx shared clock driver
does not support the clocking scheme of some of the board variants,
which are clocked from a 32768Hz (!) external crystal.
* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
ide/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, ide/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
vectors/Makefile.am: Remove.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* irq/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ide/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* ide/Makefile.am: Remove all-local: $(ARCH).
* irq/Makefile.am: Remove all-local: $(ARCH).
* clock/p_clock.c, ide/pcmcia_ide.c, include/bsp.h, include/coverhd.h,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
startup/bspstart.c, startup/bspstart.c.nocache, startup/imbx8xx.c,
startup/mmutlbtab.c, startup/setvec.c, startup/start.S,
vectors/vectors.h, vectors/vectors_init.c: URL for license changed.
ide/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/irq.c: Reflect changes to <rtems/score/cpu.h>.
Fix loopCounter.
* irq/irq_asm.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/vectors.S: Ditto.
* vectors/vectors_init.c: Include <rtems/bspIo.h>.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vector/vector.S, irq/irq_asm.S: Make sure vectors work properly
in RAM and Flash based code. The code executed for the Flash
version runs in both cases (code in Flash/code in RAM) but as it
is less efficient than the one optimized for RAM, it put it inside
ifdef. A compilation error is generated if code is linked in Flash
with the correct ifdef set...
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(), merge-in settings
from make/custom/mbx*.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* vectors/Makefile.am: remove bogus VPATH.
* wrapup/Makefile.am: Apply @exceptions@.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/bsp.h: Added include of <bsp/vectors.h>
* vectors/vectors.h: Corrected typos.
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, include/mbx.h,
irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore,
vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New files.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, network/network.c, startup/Makefile.am,
startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds,
startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am:
The modifications to this BSP reflect the conversion of the
mpc8xx CPU to the "new exception processing model."
