path: root/c/src/lib/libbsp/powerpc/mbx8xx/times-mbx821 (follow)
* Obsolete and remove powerpc/mbx8xxJoel Sherrill2016-01-231-187/+0
| | | | closes #2545.
* api: Remove deprecated NotepadsAun-Ali Zaidi2015-12-241-2/+0
| | | | | | | | | | | | | | | | | | | | | | | Notepads where a feature of RTEMS' tasks that simply functioned in the same way as POSIX keys or threaded local storage (TLS). They were introduced well before per task variables, which are also deprecated, and were barely used in favor of their POSIX alternatives. In addition to their scarce usage, Notepads took up unnecessary memory. For each task: - 16 32-bit integers were allocated. - A total of 64 bytes per task per thread. This is especially critical in low memory and safety-critical applications. They are also defined as uint32_t, and therefore are not guaranteed to hold a pointer. Lastly, they are not portable solutions for SMP and uniprocessor systems, like POSIX keys and TLS. updates #2493.
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-121-0/+191
<charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
