closes #2545.
Update #2408.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
* ep1a/startup/linkcmds, mbx8xx/startup/linkcmds,
score603e/startup/linkcmds, shared/startup/linkcmds,
ss555/startup/linkcmds: Fix typos in .eh_frame sections.
* startup/linkcmds: Correct name of ENTRY.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds:
Create bsp_get_work_area() into its own file and use BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
match the "auto clock detection" scheme in the libcpu clock driver
* startup/linkcmds: remove content of dpram section to avoid
download hangs with the EPPCBug board monitor
* startup/linkcmds: Clean up a bit after adding missing .rela sections.
* startup/linkcmds: Add .gnu.linkonce.b.* section.
* startup/linkcmds: Add sections required by newer gcc versions.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, include/mbx.h,
irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore,
vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New files.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, network/network.c, startup/Makefile.am,
startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds,
startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am:
The modifications to this BSP reflect the conversion of the
mpc8xx CPU to the "new exception processing model."
significant things:
and PowerPC
same code base.
