Conflicts:
* configure.ac, startup/bspstart.c, include/coverhd.h: Use standard
cache BSP options.
* include/irq-config.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* include/irq.h: Moved defines from 'include/irq-config.h'.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Eliminate definitions of BSP_LIBIO_MAX_FDS since this
is NOT used anywhere.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* include/bsp.h, startup/bspstart.c, startup/bspstart.c.nocache:
Eliminate copies of the Configuration Table. Use the RTEMS provided
accessor macros to obtain configuration fields.
* include/bsp.h: New header guard.
* include/commproc.h: The variable cpmp was not used anywhere but
console.c and was static in console.c, so should not have been in
this file as extern.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
Reflect changes to bsp.am.
* clock/p_clock.c, ide/pcmcia_ide.c, include/bsp.h, include/coverhd.h,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
startup/bspstart.c, startup/bspstart.c.nocache, startup/imbx8xx.c,
startup/mmutlbtab.c, startup/setvec.c, startup/start.S,
vectors/vectors.h, vectors/vectors_init.c: URL for license changed.
ide/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
PR 368/filesystem
* ide/*: added BSP support for libchip standard ide driver
* include/coverhd.h: Per PR261 removed include of
<rtems/score/targopts.h> because the file is no longer being
generated and really wasn't being used anyway.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(), merge-in settings
from make/custom/mbx*.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* vectors/Makefile.am: remove bogus VPATH.
* wrapup/Makefile.am: Apply @exceptions@.
* include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27.
* clock/p_clock.c, include/bsp.h, include/coverhd.h,
startup/bspstart.c, startup/bspstart.c.nocache, startup/setvec.c,
startup/start.S: Fixed typo.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* console/console.c, include/commproc.h, startup/start.S:
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* include/bsp.h: Added include of <bsp/vectors.h>
* vectors/vectors.h: Corrected typos.
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, include/mbx.h,
irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore,
vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New files.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, network/network.c, startup/Makefile.am,
startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds,
startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am:
The modifications to this BSP reflect the conversion of the
mpc8xx CPU to the "new exception processing model."
* console/Makefile.am, network/Makefile.am, startup/Makefile.am,
* README:
* console/console.c:
* include/bsp.h:
* network/network.c:
* startup/bspstart.c:
Add support for configuration parameters in NVRAM
* README: Updated.
* console/console.c: Addition of support for shared printk and
no termios.
* include/bsp.h: Addition of second parameter to
rtems_enet_driver_attach. Removed prototypes for printk and
BSP_output_string.
* network/network.c(rtems_enet_driver_attach): Addition of second
parameter to function.
significant things:
and PowerPC
same code base.
