closes #2545.
for details.
* configure.ac, startup/bspstart.c, include/coverhd.h: Use standard
cache BSP options.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds:
Create bsp_get_work_area() into its own file and use BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* configure.ac: Remove argument from RTEMS_PPC_EXCEPTIONS.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
ide/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, ide/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
vectors/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
Reflect changes to bsp.am.
PR 368/filesystem
* ide/*: added BSP support for libchip standard ide driver
* configure.ac: Add BSPOPTS_*(DISPATCH_HANDLER_STAT).
Remove RTEMS_ENABLE_LIBCDIR.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
* configure.ac: Add RTEMS_BSPOPTS_*(DATA_CACHE_ENABLE),
RTEMS_BSPOPTS_*(INSTRUCTION_CACHE_ENABLE).
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(), merge-in settings
from make/custom/mbx*.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* vectors/Makefile.am: remove bogus VPATH.
* wrapup/Makefile.am: Apply @exceptions@.
* configure.in: Remove.
