closes #2545.
* README:
* console/console.c:
* include/bsp.h:
* network/network.c:
* startup/bspstart.c:
Add support for configuration parameters in NVRAM
* README: Updated.
* console/console.c: Addition of support for shared printk and
no termios.
* include/bsp.h: Addition of second parameter to
rtems_enet_driver_attach. Removed prototypes for printk and
BSP_output_string.
* network/network.c(rtems_enet_driver_attach): Addition of second
parameter to function.
significant things:
and PowerPC
same code base.
