for details.
* include/irq-config.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* include/irq.h: Moved defines from 'include/irq-config.h'.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am: Eliminate bsp.am.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds:
Create bsp_get_work_area() into its own file and use BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am: Add bsppredriverhook.c.
* irq/irq.h: Attempt to correct definition of
BSP_CPM_IRQ_LOWEST_OFFSET.
* Makefile.am: Correct so it now links.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* Makefile.am: Don't include subdirs.am.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Add irq.h and vectors.h
ide/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, ide/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
vectors/Makefile.am: Remove.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* irq/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Misc cleanups and fixes.
* ide/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
ide/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
PR 368/filesystem
* ide/*: added BSP support for libchip standard ide driver
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(), merge-in settings
from make/custom/mbx*.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* vectors/Makefile.am: remove bogus VPATH.
* wrapup/Makefile.am: Apply @exceptions@.
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, include/mbx.h,
irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore,
vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New files.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, network/network.c, startup/Makefile.am,
startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds,
startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am:
The modifications to this BSP reflect the conversion of the
mpc8xx CPU to the "new exception processing model."
* console/Makefile.am, network/Makefile.am, startup/Makefile.am,
significant things:
and PowerPC
same code base.
