The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
The 32-bit ABIs for thread-local storage (TLS) and EABI read-only
small-data area have a conflicting register (r2) usage. Use the System
V small-data instead (here r2 is system reserved).
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Change SDRAM initialization according to application note AN3221.
The usage of rtems_task_wake_after() is invalid during the
driver initialization.
This is a replacement for the ATA task. The performance is much better.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
for details.
The clock driver used previously the bsp_clicks_per_usec value. For a
33333333Hz time base frequency this leads to a relative error of one per
cent for example due to integer truncation.
The change of the MSR[FP] status requires a context-synchronizing
instruction.
