* include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27.
* startup/linkcmds: Fix definition of .init and .fini sections so this
BSP will properly link with new __USE_INIT_FINI__ support.
* startup/linkcmds: Added _init and _fini.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, include/bsp.h, network/network.c,
startup/Makefile.am, startup/bspstart.c, startup/linkcmds,
wrapup/Makefile.am: Switch the eth_comm BSP to use the
"new exception processing model."
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
Also removed obsolete references to STACK_CHECKER_ON.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* canbus/Makefile.am, console/Makefile.am, network/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Include
compile.am
file to Makefile.am.
significant things:
and PowerPC
same code base.
John reports this works on the 821 and 860.
significant things:
and PowerPC
same code base.
converted to automake.
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
based board.
