* eth_comm/.cvsignore, eth_comm/ChangeLog, eth_comm/Makefile.am,
eth_comm/README, eth_comm/bsp_specs, eth_comm/configure.ac,
eth_comm/times, eth_comm/canbus/canbus.c, eth_comm/clock/p_clock.c,
eth_comm/console/console.c, eth_comm/include/.cvsignore,
eth_comm/include/8xx_immap.h, eth_comm/include/bsp.h,
eth_comm/include/canbus.h, eth_comm/include/commproc.h,
eth_comm/include/coverhd.h, eth_comm/include/info.h,
eth_comm/include/tm27.h, eth_comm/irq/irq.c, eth_comm/irq/irq.h,
eth_comm/irq/irq_asm.S, eth_comm/irq/irq_init.c,
eth_comm/network/README, eth_comm/network/network.c,
eth_comm/start/start.S, eth_comm/startup/bspstart.c,
eth_comm/startup/cpuinit.c, eth_comm/startup/linkcmds,
eth_comm/startup/mmutlbtab.c, eth_comm/vectors/vectors.S,
eth_comm/vectors/vectors.h, eth_comm/vectors/vectors_init.c,
eth_comm/wrapup/.cvsignore, eth_comm/wrapup/Makefile.am: Removed.
* startup/linkcmds: Remove SEARCH_DIR.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
* include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27.
* startup/linkcmds: Fix definition of .init and .fini sections so this
BSP will properly link with new __USE_INIT_FINI__ support.
* startup/linkcmds: Added _init and _fini.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, include/bsp.h, network/network.c,
startup/Makefile.am, startup/bspstart.c, startup/linkcmds,
wrapup/Makefile.am: Switch the eth_comm BSP to use the
"new exception processing model."
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
significant things:
and PowerPC
same code base.
based board.
