* eth_comm/.cvsignore, eth_comm/ChangeLog, eth_comm/Makefile.am,
eth_comm/README, eth_comm/bsp_specs, eth_comm/configure.ac,
eth_comm/times, eth_comm/canbus/canbus.c, eth_comm/clock/p_clock.c,
eth_comm/console/console.c, eth_comm/include/.cvsignore,
eth_comm/include/8xx_immap.h, eth_comm/include/bsp.h,
eth_comm/include/canbus.h, eth_comm/include/commproc.h,
eth_comm/include/coverhd.h, eth_comm/include/info.h,
eth_comm/include/tm27.h, eth_comm/irq/irq.c, eth_comm/irq/irq.h,
eth_comm/irq/irq_asm.S, eth_comm/irq/irq_init.c,
eth_comm/network/README, eth_comm/network/network.c,
eth_comm/start/start.S, eth_comm/startup/bspstart.c,
eth_comm/startup/cpuinit.c, eth_comm/startup/linkcmds,
eth_comm/startup/mmutlbtab.c, eth_comm/vectors/vectors.S,
eth_comm/vectors/vectors.h, eth_comm/vectors/vectors_init.c,
eth_comm/wrapup/.cvsignore, eth_comm/wrapup/Makefile.am: Removed.
* network/network.c: Add include of <sys/errno.h>.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* include/bsp.h, include/canbus.h, include/info.h,
network/network.c, startup/bspstart.c: Convert to using c99 fixed
size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* wrapup/Makefile.am: Convert to automake-building rules.
* Makefile.am: Merge-in canbus/Makefile.am, clock/Makefile.am,
console/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* canbus/Makefile.am, clock/Makefile.am, console/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
vectors/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* irq/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* canbus/Makefile.am: Eliminate VPATH.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
PR 545/bsps
* startup/setvec.c: Removed.
* startup/linkcmds: Remove SEARCH_DIR.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* canbus/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* canbus/Makefile.am: Remove all-local: $(ARCH).
* irq/Makefile.am: Remove all-local: $(ARCH).
PR 510/bsps
* irq/irq.h: Add extern C wrapper.
* bsp_specs: Remove *lib:.
* canbus/canbus.c, clock/p_clock.c, include/bsp.h, include/canbus.h,
include/coverhd.h, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, startup/bspstart.c, startup/mmutlbtab.c,
startup/setvec.c, vectors/vectors.h, vectors/vectors_init.c: URL for
license changed.
canbus/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
PR 288/rtems
* irq/irq_asm.S, startup/bspstart.c: _ISR_Nest_level is now properly
maintained.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* canbus/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* network/network.c: Removed warnings.
