PR 1917/bsps
* Makefile.am, preinstall.am, console/config.c, console/mc68360_scc.c,
console/ns16550cfg.c, console/printk_support.c: Modifications to add
dynamic tables for libchip serial drivers.
* console/polled_io.c: Update due to API changes.
* Makefile.am, console/config.c: Resolved printk issues.
* console/printk_support.c: New file.
* Makefile.am: Removed console.c and linked to the shared console.c.
Note: This change was verified through compilation only.
* console/console.c: Removed.
* configure.ac: Use standard cache BSP options.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
PR 1751/bsps
* start/start.S: Fix typo which was not caught by binutils prior to a
recent bug fix.
* console/console.c, console/ns16550cfg.c, console/polled_io.c,
include/bsp.h, include/tm27.h, startup/bspstart.c:
PR 1686/bsps
* console/console.c: Add BSP_poll_char.
* console/polled_io.c: Add BSP_poll_char.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* make/custom/ep1a.cfg: Remove RTEMS_BSP_FAMILY.
* startup/bspstart.c:
let 'save_boot_params()' return a pointer to the commandline
saved by the BSP which is NULL in this case. This pointer could
be passed on to 'boot_card()' as it is done by other BSPs.
This 'start/start.S' file however, passes a NULL pointer
directly to boot_card() (w/o ever calling save_boot_params()).
* startup/bspstart.c: Remove nested externs.
* startup/bspstart.c: Add missing prototypes.
* startup/linkcmds: Add .sbss.*.
* make/custom/ep1a.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* console/config.c: Spacing.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Remove -Qy from *link.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* console/init68360.c: Delete unused code.
* console/config.c, console/console.c, console/console.h,
console/ns16550cfg.c, console/ns16550cfg.h, include/bsp.h,
include/tm27.h, irq/irq_init.c, irq/openpic_xxx_irq.c,
pci/no_host_bridge.c: File head clean up.
* console/debugio.c: Removed.
* preinstall.am: Regenerated.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Use standardized bsp_cleanup() which can optionally
print a message, poll for user to press key, and call bsp_reset().
Using this eliminates the various bsp_cleanup() implementations which
had their own implementation and variety of string constants.
* Makefile.am, include/bsp.h, startup/bspstart.c: Use PowerPC level
shared bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* Makefile.am, configure.ac, console/rsPMCQ1.h, include/bsp.h,
startup/bspstart.c: Create bsp_get_work_area() into its own file and
use BSP Framework to perform more initialization.
* startup/bspgetworkarea.c: New file.
* startup/bspstart.c: Review of all bsp_cleanup() implementations. In
this phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* console/config.c, console/console.h: Convert to "bool".
* console/config.c: Convert to "bool".
* Makefile.am, configure.ac, console/alloc360.c, console/console.c,
console/console.h, console/m68360.h, console/mc68360_scc.c,
console/ns16550cfg.c, console/rsPMCQ1.c, console/rsPMCQ1.h,
include/bsp.h, irq/irq_init.c, vme/VMEConfig.h: Initiate update and
testing. Add missing files. Does not run hello yet.
* console/debugio.c, console/polled_io.c, irq/openpic_xxx_irq.c: New files.
* console/mc68360_scc.c, console/rsPMCQ1.c, console/rsPMCQ1.h,
irq/irq_init.c, pci/no_host_bridge.c, startup/bspstart.c:
