* | Renamed config.c to conscfg.c to avoid naming conflicts. | Joel Sherrill | 1999-05-28 | 1 | -283/+0 |
* | Card Resource Register was a 16-bit register not a 32-bit one. | Joel Sherrill | 1998-08-06 | 1 | -6/+12 |
| | | | | Used existing constants for bits on the register. | ||||
* | Added support for the Card Resource Register. The new probe routines | Joel Sherrill | 1998-08-06 | 1 | -3/+27 |
| | | | | | check for the presence of the DUART, SCC, and RTC. The SONIC check needs to be added in the future as the network driver is libchip'ed. | ||||
* | Removed "if 0" used to switch between serial ports. | Joel Sherrill | 1998-07-25 | 1 | -2/+0 |
* | Changed so we could test interrupts on port 3. | Joel Sherrill | 1998-07-18 | 1 | -2/+2 |
* | Removed use of data port for z8530. | Joel Sherrill | 1998-07-18 | 1 | -7/+7 |
| | | | | | Tested all four ports. MC68681 as both polled and interrupt. Z8530 as polled only. | ||||
* | Added z85c30 specific probe routine to decide what the clock rate was. | Joel Sherrill | 1998-07-18 | 1 | -4/+26 |
| | | | | | | This routines could be enhanced to determine if the SCC is present since it appears from the DY-4 manual that a status registers indicates this. | ||||
* | Fixed typo in which last port did not get switched to default | Joel Sherrill | 1998-07-15 | 1 | -4/+4 |
| | | | | register access routines. | ||||
* | Switched to usign the default z8530 and mc68681 register access routines. | Joel Sherrill | 1998-07-15 | 1 | -10/+8 |
* | Added chip type identifier field. This was necessary because a single | Joel Sherrill | 1998-07-15 | 1 | -0/+4 |
| | | | | interrupt vector can be shared by multiple chips of varying types. | ||||
* | Switched from polling to interrupts and in the process added a conditional | Joel Sherrill | 1998-07-15 | 1 | -4/+17 |
| | | | | | compilation section which used CONSOLE_USE_INTERRUPTS to switch all ports between interrupt and polled mode. | ||||
* | Added board specific baud rate table and set driver function table | Joel Sherrill | 1998-07-09 | 1 | -8/+103 |
| | | | | to polled. | ||||
* | New file added in the process of converting the console driver to | Joel Sherrill | 1998-07-05 | 1 | -0/+123 |
libchip/serial. |
