Update #3285.
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
* console/console.c (ISS_output_char): Add return type.
* timer/timer.c: Remove unused vars "old_ie".
* Makefile.am, console/console.c, startup/linkcmds: Now links but
clearly the starting stack overlaps regular memory and needs to be
moved.
* Makefile.am, console/console.c: Use shared polled console framework.
* console/console.c, include/bsp.h, startup/bspstart.c: Move
interrupt_stack_size field from CPU Table to Configuration Table.
Eliminate CPU Table from all ports. Delete references to CPU Table in
all forms.
* console/console.c, startup/bspstart.c: Moved most of the remaining
CPU Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
nios2_iss/ChangeLog, nios2_iss/Makefile.am, nios2_iss/bsp_specs,
nios2_iss/configure.ac, nios2_iss/nios2_iss.ptf,
nios2_iss/nios2_iss.sh, nios2_iss/times, nios2_iss/console/console.c,
nios2_iss/include/bsp.h, nios2_iss/include/bspopts.h.in,
nios2_iss/include/coverhd.h, nios2_iss/include/tm27.h,
nios2_iss/shmsupp/addrconv.c, nios2_iss/shmsupp/getcfg.c,
nios2_iss/shmsupp/lock.c, nios2_iss/shmsupp/mpisr.c,
nios2_iss/start/crtnn.s, nios2_iss/start/start.S,
nios2_iss/startup/bspclean.c, nios2_iss/startup/bspstart.c,
nios2_iss/startup/linkcmds, nios2_iss/startup/main.c,
nios2_iss/startup/setvec.c, nios2_iss/timer/timer.c: New files.
