* bsp_specs: Remove %cpp.
* console/console-io.c: Remove unused variable i.
* include/bsp.h: New header guard.
* clock/clockdrv.c, include/bsp.h, network/network.c,
startup/bspstart.c, timer/timer.c: Eliminate unsigned{8|16|32}.
* startup/idtmem.S: Eliminate warnings and be more consistent with
other MIPS assembly.
* clock/clockdrv.c: Add include of rtems/bspIo.h.
* include/tm27.h: Delete TX3904 code and leave stub.
* network/network.c: Eliminate warnings.
* startup/bspclean.c: Add include of rtems/bspIo.h. Reformat.
* include/.cvsignore: Fixed typo.
* network/network.c: Now compiles with GCC 4.0.
* .cvsignore, ChangeLog, include/.cvsignore: New files.
* acinclude.m4: Added csb350 to list of BSPs.
* csb350/Makefile.am, csb350/README, csb350/bsp_specs,
csb350/configure.ac, csb350/times, csb350/clock/clockdrv.c,
csb350/console/console-io.c, csb350/include/bsp.h,
csb350/include/tm27.h, csb350/network/network.c, csb350/start/regs.S,
csb350/start/start.S, csb350/startup/bspclean.c,
csb350/startup/bspstart.c, csb350/startup/linkcmds,
csb350/timer/timer.c: New BSP.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Fix typo.
* Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* console/led.S, liblnk/lnklib.S, start/start.S, startup/idtmem.S,
startup/idttlb.S: Include <rtems/mips/iregdef.h> instead of
<iregdef.h>.
startup/idttlb.S, startup/inittlb.c: Include <rtems/mips/idtcpu.h>
instead of <idtcpu.h>.
* console/led.S: Include <rtems/asm.h> instead of <asm.h>.
* start/start.S: Include <rtems/asm.h> instead of <asm.h>.
* startup/idtmem.S: Include <rtems/asm.h> instead of <asm.h>.
* startup/idttlb.S: Include <rtems/asm.h> instead of <asm.h>.
* times, include/bsp.h, startup/bspstart.c: Convert to using c99
fixed size types.
* clock/clockdrv.c, include/bsp.h, startup/bspstart.c,
timer/timer.c: Convert to using c99 fixed size types.
startup/gdb-support.c, timer/timer.c: Convert to using c99 fixed
size types.
* Makefile.am: Correct typo.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* acinclude.m4: Regenerate.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Correct path to clockdrv_shell.c.
* Makefile.am: Merge-in console/Makefile.am, liblnk/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* console/Makefile.am, liblnk/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Remove.
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
* start/start.S: Replace #-ASM-style comments with C-/**/ comments.
* start/reg.S: Remove //-comments
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* Makefile.am: Remove times from EXTRA_DIST (Non-existant).
* startup/Makefile.am: Remove exit.c, setvec.c from EXTRA_DIST.
* console/Makefile.am: Remove console.c from EXTRA_DIST.
* startup/Makefile.am: Remove bspclean.c, exit.c, setvec.c from
EXTRA_DIST.
* startup/Makefile.am: Ditto.
