* | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-07 | 1 | -129/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mips64orion/.cvsignore, mips64orion/ChangeLog, mips64orion/Makefile.am, mips64orion/README, mips64orion/acinclude.m4, mips64orion/configure.ac, mips64orion/p4000/.cvsignore, mips64orion/p4000/ChangeLog, mips64orion/p4000/Makefile.am, mips64orion/p4000/README, mips64orion/p4000/bsp_specs, mips64orion/p4000/configure.ac, mips64orion/p4000/times, mips64orion/p4000/console/.cvsignore, mips64orion/p4000/console/Makefile.am, mips64orion/p4000/console/console.c, mips64orion/p4000/console/led.S, mips64orion/p4000/include/.cvsignore, mips64orion/p4000/include/bsp.h, mips64orion/p4000/include/coverhd.h, mips64orion/p4000/liblnk/.cvsignore, mips64orion/p4000/liblnk/Makefile.am, mips64orion/p4000/liblnk/lnklib.S, mips64orion/p4000/start/.cvsignore, mips64orion/p4000/start/Makefile.am, mips64orion/p4000/start/start.S, mips64orion/p4000/startup/.cvsignore, mips64orion/p4000/startup/Makefile.am, mips64orion/p4000/startup/bspclean.c, mips64orion/p4000/startup/bspstart.c, mips64orion/p4000/startup/ghlinkcmds, mips64orion/p4000/startup/idtmem.S, mips64orion/p4000/startup/idttlb.S, mips64orion/p4000/startup/inittlb.c, mips64orion/p4000/startup/linkcmds, mips64orion/p4000/startup/setvec.c, mips64orion/p4000/wrapup/.cvsignore, mips64orion/p4000/wrapup/Makefile.am: Removed. | ||||
| | | | | | | * console/console.c, include/bsp.h, include/coverhd.h, startup/bspclean.c, startup/bspstart.c, startup/setvec.c: URL for license changed. | ||||
* | 2001-09-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-09-28 | 1 | -2/+3 |
| | | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay(). | ||||
* | 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-06-18 | 1 | -0/+2 |
| | | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -0/+9 |
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 1 | -6/+0 |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | ||||
* | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1998-03-21 | 1 | -8/+0 |
| | | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | removed reference to no_bsp. | Joel Sherrill | 1997-04-07 | 1 | -4/+10 |
| | | | | added prototypes. | ||||
* | added $Id$ string to file header | Joel Sherrill | 1996-09-11 | 1 | -1/+7 |
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 1 | -0/+120 |
Derrick Ostertag (ostertag@transition.com). |
