* | bsps: Move startup files to bsps | Sebastian Huber | 2018-04-20 | 1 | -188/+0 |
| | | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | rbtx4938: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 1 | -0/+3 |
* | Add RTEMS linker sets | Sebastian Huber | 2015-12-08 | 1 | -0/+2 |
| | | | | Update #2408. | ||||
* | bsps: Fix TLS support in linker command files | Sebastian Huber | 2014-04-22 | 1 | -1/+3 |
| | | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section. | ||||
* | bsps: Thread-local storage (TLS) for linkcmds | Sebastian Huber | 2014-02-04 | 1 | -0/+18 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-07-19 | 1 | -2/+1 |
* | 2010-04-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-27 | 1 | -3/+1 |
| | | | | | * startup/linkcmds: Revert previous change. Remove .reginfo from .bss section where it was present. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 1 | -1/+2 |
| | | | | * startup/linkcmds: Add NOLOAD to .bss to eliminate warnings. | ||||
* | 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-16 | 1 | -2/+4 |
| | | | | | | * Makefile.am, startup/linkcmds: Use top level shared bsp_get_work_area() implementation. * startup/bspgetworkarea.c: Removed. | ||||
* | 2008-03-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-03-03 | 1 | -1/+1 |
| | | | | | * startup/linkcmds: Add wildcard to gcc_except_table section so programs compiled with gcc 4.3.x can link. | ||||
* | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 1 | -0/+163 |
