* | bsps: Move PCI drivers to bsps | Sebastian Huber | 2018-04-23 | 1 | -1102/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | libbsp/malta/pci/pci.c: Correct printk() formats | Joel Sherrill | 2017-03-09 | 1 | -6/+6 |
* | pci.h cleanup - Consolidate common defines to cpukit pci.h | Joel Sherrill | 2012-05-16 | 1 | -5/+2 |
| | | | | | | | | | | | | | + libbsp/sparc/shared/include/pci.h was largely a copy of an older version of the cpukit pci.h. Removed much of the contents and included <rtems/pci.h>. + sparc/*/pci*.c - Move to <rtems/pci.h> required updating to use uint32_t for dword accesses. + Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION + Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove PCI_MULTI_FUNCTION definitions in C files. + Move PCI_INVALID_VENDORDEVICEID definitions from various C files to cpukit pci.h | ||||
* | Add MIPS/Malta BSP. | Jennifer Averett | 2012-04-04 | 1 | -0/+1105 |
