* | jmr3904/tools: Remove obsolete tools | Joel Sherrill | 2016-01-14 | 3 | -312/+0 |
* | Update bug report URL | Sebastian Huber | 2014-12-05 | 1 | -1/+1 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -136/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 2 | -0/+6 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 1 | -0/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -8/+0 |
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2011-01-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-01-28 | 1 | -1/+1 |
| | | | | | | | | * csb350/clock/clockdrv.c, csb350/network/network.c, csb350/start/start.S, csb350/timer/timer.c, genmongoosev/clock/clockdrv.c, genmongoosev/timer/timer.c, jmr3904/timer/timer.c, jmr3904/tools/runtest.in: Fix typo where license said found in found in. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | 2009-01-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-01-06 | 3 | -42/+28 |
| | | | | | | | | * configure.ac: Make runtest an autoconf generated file so we can insert target alias. Also detect more program termination conditions so tests are killed more reliably. * runtest.in: New file. * runtest: Removed. | ||||
* | 2008-08-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-15 | 2 | -8/+12 |
| | | | | * runtest: Attempt to prevent runaways. | ||||
* | 2008-08-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-07 | 2 | -26/+43 |
| | | | | * runtest: Major update. Now more likely not to run away. | ||||
* | 2008-08-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-05 | 2 | -0/+5 |
| | | | | * runtest: Strip .exe or .ralf from file names. | ||||
* | Cleanup. | Ralf Corsepius | 2008-07-14 | 1 | -6/+0 |
* | 2008-03-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-03-11 | 2 | -1/+5 |
| | | | | * runtest: Update version. | ||||
* | 2008-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-03-11 | 2 | -1/+5 |
| | | | | * runtest: Skip all fatal error tests. | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-04 | 2 | -1/+6 |
| | | | | | * runtest: Add capture to list of interative tests to skip in batch mode. | ||||
* | 2007-04-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-04-17 | 1 | -1/+1 |
| | | | | * jmr3904/tools/runtest: Do not run pppd.exe from batch mode script. | ||||
* | 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-26 | 2 | -1/+5 |
| | | | | * Makefile.am: Use MKDIR_P instead of mkdir_p. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-11-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-11-17 | 2 | -1/+5 |
| | | | | * runtest: Change toolname to match 4.8. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-06-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-24 | 2 | -0/+6 |
| | | | | * configure.ac: | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+8 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+5 |
| | | | | * Makefile.am: Reworked. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 2 | -9/+17 |
| | | | | * Makefile.am: install runtest to bsptools_bindir. | ||||
| | | | | | | * console/console-io.c, include/bsp.h, startup/bspclean.c, startup/bspstart.c, timer/timer.c, tools/runtest: URL for license changed. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 2 | -1/+5 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 2 | -1/+5 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-14 | 2 | -1/+5 |
| | | | | * runtest: Add fileio to list of interactive tests. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 3 | -3/+9 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+21 |
| | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. | ||||
* | 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -19/+0 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 2 | -0/+7 |
* | 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-09-27 | 2 | -1/+5 |
| | | | | * Makefile.am: Use 'TMPINSTALL_FILES ='. |
