updates #2448.
do
echo $b
# echo $g
-i $b
done
Putting the duart in libcpu was very optimistic and presumptuous.
It has never been used again on another SoC and is BSP specific.
promCopyIcacheFlush.
* include/bsp.h: Add prototypes of promCopyDcacheFlush and
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h: New header guard.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* start/start.S: Include <rtems/asm.h> instead of <asm.h>.
* clock/clockdrv.c, include/bsp.h, startup/bspstart.c,
startup/gdb-support.c, timer/timer.c: Convert to using c99 fixed
size types.
* clock/clockdrv.c, console/conscfg.c, include/bsp.h,
startup/bspstart.c, startup/gdb-support.c, timer/timer.c: URL for
license changed.
* Update of BSP to address problems restarting, provide more
information during boot, and better handle ROM vs RAM images.
* README, include/bsp.h, start/regs.S, start/start.S,
startup/bspstart.c, startup/linkcmds, timer/timer.c: Updated
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
* Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>.
* clock/clockdrv.c, console/conscfg.c: Corrected.
* include/bsp.h: Support for tm27 and addition of CPU_CLOCK_RATE.
* startup/bspstart.c: Properly set initial status register and
pending interrupts.
* timer/timer.c: Works now.
* clock/clockdrv.c, console/conscfg.c, include/bsp.h, start/start.S,
startup/bspstart.c, timer/timer.c: Comments corrected.
* The Generic Mongoose-V BSP uses only the peripherals found on
the Synova Mongoose-V CPU. This is a radiation hardened CPU
based on the LSI Logic 33K.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in,
clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/conscfg.c,
start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S,
startup/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files.
