path: root/c/src/lib/libbsp/mips/csb350/make/custom/csb350.cfg (follow)
* bsps: Move make/custom/* files to bspsSebastian Huber2018-04-231-19/+0
| | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
* bsps/mips: Move libcpu content to bspsSebastian Huber2018-03-131-1/+0
* mips/csb350: Add per-section compilation and linking support.Ralph Holmes2016-01-201-0/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The size of the sample executables without this option were: text data bss dec hex filename 114476 8176 25808 148460 243ec base_sp.exe 135980 7292 25664 168936 293e8 hello.exe 48900 3628 21168 73696 11fe0 minimum.exe 593388 80288 37992 711668 adbf4 fileio.exe 137100 9992 25960 173052 2a3fc nsecs.exe 210124 20976 25904 257004 3ebec paranoia.exe 117948 8360 25232 151540 24ff4 ticker.exe 117308 8384 28912 154604 25bec unlimited.exe 1068972 48272 32688 1149932 118bec cxx_iostream.exe 237188 19372 26048 282608 44ff0 cdtest.exe 226092 22360 28020 276472 437f8 capture.exe The size of the sample executables with this option enabled were: text data bss dec hex filename 100632 7484 26016 134132 20bf4 base_sp.exe 119704 6588 25232 151524 24fe4 hello.exe 36232 2968 21184 60384 ebe0 minimum.exe 568984 77192 37832 684008 a6fe8 fileio.exe 124984 9260 25480 159724 26fec nsecs.exe 195656 20252 25744 241652 3aff4 paranoia.exe 105352 7652 25216 138220 21bec ticker.exe 101640 7664 28912 138216 21be8 unlimited.exe 557072 39024 32624 628720 997f0 cxx_iostream.exe 218540 17316 26272 262128 3fff0 cdtest.exe 209704 21316 27012 258032 3eff0 capture.exe
* 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-211-3/+0
| | | | * make/custom/csb350.cfg: Remove RTEMS_BSP_FAMILY.
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+22
* make/custom/csb350.cfg: New (relocated from /make/custom).
