Close #3250.
Close #4081.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3387.
upgrade to that version.
Close #3387.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3250.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
for details.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, console/console-io.c: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspclean.c: Removed.
* Makefile.am, configure.ac, startup/bspstart.c: Split out
bsp_get_work_area() into its own file and user BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* configure.ac: Require automake-1.9.
* acinclude.m4: Added csb350 to list of BSPs.
* csb350/Makefile.am, csb350/README, csb350/bsp_specs,
csb350/configure.ac, csb350/times, csb350/clock/clockdrv.c,
csb350/console/console-io.c, csb350/include/bsp.h,
csb350/include/tm27.h, csb350/network/network.c, csb350/start/regs.S,
csb350/start/start.S, csb350/startup/bspclean.c,
csb350/startup/bspstart.c, csb350/startup/linkcmds,
csb350/timer/timer.c: New BSP.
