* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
* startup/init68360.c: Modifications to make gcc 3.x happy.
* README: Bring it more in line with reality.
* start/start.S: Reverse sense of conditional compilation so the
code will compile for a cpu32.
* include/Makefile.am: Fixed typo.
* configure.in: Correct typo.
* consolex/Makefile.am: Ditto.
* include/Makefile.am: Fix typo in include_HEADERS.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
wrapup/Makefile.am: Modified to include compile.am.
* startup/bspstart.c: Removed include of <libcsupport.h>
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
* README, clock/Makefile.am, clock/ckinit.c, clock/clock.c:
Clock driver updated to use shell driver mechanism.
* clock/ckinit.c: Removed.
* clock/clock.c: New file.
* start/start.S: Added space for vectors on CPU32 configuration.
* startup/bspstart.c: Fixed typo.
* startup/linkcmds: Set _VBR to 0 to indicate that the vectors are
in RAM not ROM. Thanks to Juan Zamorano <jzamora@fi.upm.es> for
debugging this.
* Makefile.am: Removed unneeded blank line.
* network/network.c: Removed unused variable warnings.
* Makefile.am, configure.in, include/Makefile.am,
wrapup/Makefile.am: Updated to reflect addition of network driver
by Franck Julien <FranckJ@cxr.fr>.
* include/m302_int.h, network/.cvsignore, network/Makefile.am,
network/network.c: New file.
* README, sim68000.setup, clock/clockdrv.c: Modified to add
support for timer as clock tick source. Compiles but untested.
* start/start.S, startup/bspstart.c: Not functional for CPU32
but hopefully will compile now and give a warning saying that
the CPU32 variant needs work.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
* shared/bsppretaskinghook.c: assoc.h, error.h, libio_.h, libio.h,
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* clock/ckinit.c: Do not just set the IMR, OR the enable bit in.
* start/start.c: Modified to support generation of ram_init.
* start/ram_init.ld, BSP/start/ram_init.sed: New files.
These changes enable RTEMS to automatically generate
the ram_init file used by gdb with the BDM patches. The 332 has
on-board chip select lines (for RAM and FLASH) that must be
configured before use of these peripherals. These patches parse
data from start.c where the chip select lines are configured in
the runtime executable and automatically generates the gdb
initialization file using the same settings. A great time saver.
A similar file, ram_init_FW (flash writable), is also generated
that the flash programming tool uses.
* start/Makefile.am: Modified to support above.
* CPU/sim.h: Modified to support above.
* startup/except_vect_332_ROM.S: Moved to start so it would not
be included in libbsp.a. Moving it to start ensures it is
available as a single object file.
* start/except_vect_332_ROM.S: Moved from startup.
* startup/linkcmds, startup/linkcmds_ROM: Fixes to the memory map
shown in the comments.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* include/mvme16x_hw.h: Include rtems/score/targopts.h so we
can check which BSP this is being used with.
* network/network.c (uti596_attach): Adjust cpp directives
and conditional braces so all cases compile.
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
* clock/Makefile.am, console/Makefile.am, fatal/Makefile.am,
wrapup/Makefile.am, network/Makefile.am: Include compile.am
* clock/Makefile.am, console/Makefile.am, consolex/Makefile.am,
tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include
compile.am
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
* include/mvme16x_hw.h: Added NVRAM_CONFIGURE macro in
a manner that should work for 162, 162lx, and 167.
* console.c(_BSP_output_char): Output CR after LF for printk.
* README: Updated
* console/console.c: Fix polled input.
Add support for shared printk.
Add support for more flexible polled I/O with and without termios.
I/O mode and console is selectable either from NVRAM or from
mvme167.cfg. Clean up comments.
* README: Updated
2000-08-11 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* startup/page_table.c (page_table_init): Reorganize NVRAM parameters.
* include/bsp.h: Reorganize NVRAM parameters.
* times: These are the times for the MVME167, not the MBX860-002.
2000-08-11 John Cotton <john.cotton@nrc.ca>
* network/network.c: Fix NVRAM configuration parameter
handling from previous revision.
Check J1-4, restructure NVRAM parameter handling.
* network/network.c: Cleanup of network driver to reduce warnings.
Addition of second parameter to uti596_attach.
to driver attach routine.
