Update #3285.
Update #2825.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
PR 1824/cpukit
* startup/bspclean.c: Return exit/shutdown status back to boot_card().
boot_card() propagates this to bsp_cleanup() and returns it to the
assembly that started the application. bsp_cleanup() prototype
changed.
* network/network.c, startup/bspclean.c, startup/init5282.c: Remove
warnings.
* clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h,
include/tm27.h, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5282.c, startup/linkcmds,
timer/timer.c: Correct license URL and/or fix mistake in copyright
notice. Both of these mistakes appear to be from code submitted after
these changes were made previously.
Call bsp_reset from bsp_cleanup().
