* Makefile.am, configure.ac, startup/linkcmds: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* console/debugio.c, startup/bsppredriverhook.c: New files.
* startup/bspstart.c: Removed.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* startup/bspstart.c: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* startup/bspstart.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* clock/clockdrv.c, console/conscfg.c, include/bsp.h,
startup/bspstart.c: Convert to using c99 fixed size types.
* console/conscfg.c, include/bsp.h, startup/bspstart.c,
startup/spurious_assistant.c: URL for license changed.
* console/conscfg.c, startup/bspstart.c: Removed warnings.
* startup/bspstart.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/spurious_assistant.c: Include rtems/bspIo.h instead of bspIo.h.
* start/start.S: Added space for vectors on CPU32 configuration.
* startup/bspstart.c: Fixed typo.
* start/start.S, startup/bspstart.c: Not functional for CPU32
but hopefully will compile now and give a warning saying that
the CPU32 variant needs work.
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
