path: root/c/src/lib/libbsp/m68k/sim68000/make (follow)
* m68k/sim68000: RemoveAun-Ali Zaidi2015-12-082-40/+0
| | | | closes #2445.
* Use $(EXEEXT) [defaults to "exe"] to generate binariesNick Withers2013-08-092-2/+2
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-112-4/+0
* 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-212-6/+0
| | | | | * make/custom/sim68000.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/simcpu32.cfg: Remove RTEMS_BSP_FAMILY.
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+50
* make/custom/sim68000.cfg: New (relocated from /make/custom). * make/custom/simcpu32.cfg: New (relocated from /make/custom).
