closes #2445.
* console/debugio.c: Include <unistd.h>.
* Makefile.am, configure.ac, startup/linkcmds: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* console/debugio.c, startup/bsppredriverhook.c: New files.
* startup/bspstart.c: Removed.
