Update #3285.
output.
* timer/timer.c, timer/timerisr.S: Eliminate empty function from every
benchmark timer driver. Fix spelling.
* timer/timer.c, timer/timerisr.S: Rename timer driver methods to
follow RTEMS programming conventions.
* clock/ckinit.c, console/console-recording.c, console/console.c,
fatal/bspfatal.c, include/bsp.h, include/coverhd.h, include/fatal.h,
include/page_table.h, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, timer/timer.c, timer/timerisr.S: URL for license
changed.
