Update #3285.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
* console/console.c, fatal/bspfatal.c, startup/bspclean.c,
startup/page_table.c:
* console/console.c: Add BSP_poll_char.
* console/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* console/console.c, timer/timer.c: Fix warnings and typos.
* console/console.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
PR 1370/bsps
* console/console.c: mvme167 console driver BSP_output_char fails to
convert \n -> \n\r
* console/console.c: Eliminate copies of switches to convert termios
Bxxx constants to xxx as an integer. Use the shared
termios_baud_to_number() routine to do the same conversion.
* clock/ckinit.c, console/console-recording.h, console/console.c,
fatal/bspfatal.c, include/fatal.h, network/network.c,
network/uti596.h, startup/bspstart.c, timer/timer.c: Convert to
using c99 fixed size types.
* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am
fatal/Makefile.am, network/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am.
* clock/Makefile.am, console/Makefile.am, fatal/Makefile.am,
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am: Remove.
* console/console-recording.c: Remove (rename to console-recording.h).
* console/console-recording.h: New.
* fatal/Makefile.am: Cosmetics.
* network/Makefile.am: Cosmetics.
* fatal/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console-recording.c, console/console.c,
fatal/bspfatal.c, include/bsp.h, include/coverhd.h, include/fatal.h,
include/page_table.h, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, timer/timer.c, timer/timerisr.S: URL for license
changed.
* console/Makefile.am: Remove BSP_CPPFLAGS.
* configure.ac: Add BSPOPTS PRINTK_MINOR and CONSOLE_MINOR.
* console/Makefile.am: Don't include @RTEMS_BSP@.cfg
fatal/Makefile.am: Reflect having moved automake.
* console/Makefile.am: Eliminate C_O_FILES.
* fatal/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/console.c: Removed warnings.
* fatal/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
startup/page_table.c: Per PR200 fix multi-line inline assembly
to satisfy gcc 3.1 and newer.
* fatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
wrapup/Makefile.am, network/Makefile.am: Include compile.am
* console.c(_BSP_output_char): Output CR after LF for printk.
* README: Updated
* console/console.c: Fix polled input.
Add support for shared printk.
Add support for more flexible polled I/O with and without termios.
I/O mode and console is selectable either from NVRAM or from
mvme167.cfg. Clean up comments.
2000-08-11 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* startup/page_table.c (page_table_init): Reorganize NVRAM parameters.
* include/bsp.h: Reorganize NVRAM parameters.
* times: These are the times for the MVME167, not the MBX860-002.
2000-08-11 John Cotton <john.cotton@nrc.ca>
* network/network.c: Fix NVRAM configuration parameter
handling from previous revision.
Check J1-4, restructure NVRAM parameter handling.
* network/network.c: Cleanup of network driver to reduce warnings.
Addition of second parameter to uti596_attach.
converted to automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
