* | bsps: Move startup files to bsps | Sebastian Huber | 2018-04-20 | 1 | -196/+0 |
| | | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 1 | -7/+7 |
| | | | | | * startup/bspclean.c, startup/page_table.c: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 1 | -2/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 1 | -11/+11 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -2/+0 |
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 1 | -10/+10 |
| | | | | * startup/page_table.c: Removed warnings. | ||||
* | added or fixed includes of page_table.h to eliminate warnings. | Joel Sherrill | 1997-04-07 | 1 | -2/+3 |
* | file lost in crash and re-added | Joel Sherrill | 1995-12-19 | 1 | -0/+201 |
