startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
timer/timer.c: URL for license changed.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
converted to automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
.s files to .S in conformance with GNU conventaons. This is a
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
(Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and
T.N.I. (Brest, France)
