closes #2444.
* Makefile.am, clock/ckinit.c, startup/bspstart.c, startup/linkcmds:
Add use of bsp_get_work_area() in its own file and rely on BSP
Framework to perform more initialization. Remove unnecessary includes
of rtems/libio.h and rtems/libcsupport.h.
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* mvme136/clock/ckinit.c, mvme136/startup/bspclean.c,
mvme136/startup/bspstart.c, mvme136/timer/timer.c: Include
<rtems/m68k/zilog/z8036.h> instead of <zilog/z8036.h>.
* clock/ckinit.c, include/bsp.h, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspstart.c, timer/timer.c: Convert to using
c99 fixed size types.
shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, timer/timer.c, timer/timerisr.S: URL for license
changed.
like signal dispatching.
