Update #3285.
Updates #3520.
Update #2408.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Changed console driver to use interrupts instead of polling.
Change to avoid overwriting CPU32Bug interrupt vector when setting up the Sci interrupt handler.
Fixed type for boolean flag in bsp.h.
Changed mrm332.h to use 25Mhz clock.
Fixes to mrm332.cfg to use correct mcpu32 value for RTEMS_CPU_MODEL instead of m68332 which is no longer supported.
Added -mcpu=cpu32 to compiler options.
Removed broken ROM linker script and replaced broken RAM linker script with working ROM linker script.
Removed no longer required file except_vect_332_ROM.S.
Enabled 0xbeefbeef magic string in start.S to allow MRM version of CPU32Bug to auto run RTEMS.
Removed old code from start.S
Changed compiler optimization flag to optimize for size.
* Makefile.am, startup/linkcmds, startup/linkcmds_ROM: Use top level
shared bsp_get_work_area() implementation.
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds,
startup/linkcmds_ROM: Add use of bsp_get_work_area() in its own file
and rely on BSP Framework to perform more initialization. Remove
unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* startup/bsppredriverhook.c: New file.
* startup/linkcmds, startup/linkcmds_ROM: Add wildcard to
gcc_except_table section so programs compiled with gcc 4.3.x can
link.
* startup/linkcmds: Handle .data.* sections
* startup/linkcmds, startup/linkcmds_ROM: Add sections required by
newer gcc versions.
* startup/linkcmds, startup/linkcmds_ROM: Add new bss sections .bss.*
and .gnu.linkonce.b*.
* console/sci.c, include/mrm332.h, startup/linkcmds,
startup/linkcmds_ROM: Various updates to make this run properly
from ROM.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* console/sci.c, console/sci.h,
console/console.c: Added new SCI driver.
* start/start.c: Removed file.
* start/start.S: New file, the asm portion of the updated start code.
* start/configure.am: Added start.S, removed start.c
* startup/start_c.c: New file, the C portion of the updated start code. Contains most of the code that was in the old start.c.
* startup/configure.am: Added start_c.c to C_FILES.
* include/bsp.h: Added include <rtems/bspIo.h>
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
