Update #3285.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
Add bsp_generic_fatal().
Use rtems_fatal() instead of bsp_cleanup().
PR 1824/cpukit
* misc/interr.c, spurious/spinit.c: Return exit/shutdown status back to
boot_card(). boot_card() propagates this to bsp_cleanup() and returns
it to the assembly that started the application. bsp_cleanup()
prototype changed.
* include/bsp.h, include/mrm332.h, spurious/spinit.c:
* spurious/spinit.c: Add include of bootcard.h to fix warning.
* console/console.c, console/sci.c, console/sci.h, spurious/spinit.c,
startup/bspclean.c, startup/start_c.c: Convert C++ style comments to
C style.
spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* spurious/Makefile.am: Cosmetics.
* spurious/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console.c, include/bsp.h, misc/interr.c,
spurious/spinit.c, startup/bspclean.c, startup/bspstart.c,
timer/timer.c: URL for license changed.
spurious/Makefile.am: Reflect having moved automake.
* spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/sci.c, spurious/spinit.c: Removed warnings.
* spurious/Makefile.am: Use .$(OBJEXT) instead of .o.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
* console/sci.c, console/sci.h,
console/console.c: Added new SCI driver.
* start/start.c: Removed file.
* start/start.S: New file, the asm portion of the updated start code.
* start/configure.am: Added start.S, removed start.c
* startup/start_c.c: New file, the C portion of the updated start code. Contains most of the code that was in the old start.c.
* startup/configure.am: Added start_c.c to C_FILES.
* include/bsp.h: Added include <rtems/bspIo.h>
wrapup/Makefile.am: Modified to include compile.am.
* startup/bspstart.c: Removed include of <libcsupport.h>
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
