path: root/c/src/lib/libbsp/m68k/mrm332/misc/dotests (follow)
* bsps: Move documentation, etc. files to bspsSebastian Huber2018-04-261-12/+0
| | | | | | This patch is a part of the BSP source reorganization. Update #3285.
* Remove CVS Id Strings (manual edits after script)Joel Sherrill2012-05-111-3/+0
| | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
* 2000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill2001-05-251-0/+15
* New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * .cvsignore, ChangeLog Makefile.am, README, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in, console/.cvsignore, console/Makefile.am, console/console.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c, spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c, start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore, startup/Makefile.am, startup/bspclean.c, startup/bspstart.c, startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM, timer/.cvsignore, timer/Makefile.am, timer/timer.c, times, wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
